boundary type specifications
Old   September 10, 2009, 05:47
Default boundary type specifications
Alessandro Rosa
Agovale46 is on a distinguished road
hello to everybody.
I have water that flows over a solid body. The water 's volume and the solid' volume are not connected each other, thereby in the boundary among the two volumes ,there are 2 overlap surfaces, meshed in 2 different way. the question is: when i do the boundary type specifications, i have to do it only for one surface in the interface, or i have to do it for both? and what kind of the specification type do i have to put over the two surfaces ( there's the concenction phenomena ,obviously)?
Last edited by Agovale46; September 10, 2009 at 05:49. Reason: kind of boundary specication type
Agovale46 is offline   Reply With Quote
Old   September 10, 2009, 08:46
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
*except if you want to compute conduction, you don't need the solid volume.
So you can delete it. Your computation's model will be simply the fluid domain with a hole (solid volume substracted)
*if you solve also conduction, I never used this feature, but I would try to connect the 2 volumes, and define the solid one as solid
check help, because I am not familiar with solid conduction
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
kind of specificat
Specifying nonuniform initial condition msyaml OpenFOAM Running, Solving & CFD 65 April 25, 2016 04:23
pipe with buoyantFoam buoyancy, boundary conditions Thomas Baumann OpenFOAM 0 June 15, 2009 08:58
FOAM FATAL IO ERRORsimpleFoam hariya03 OpenFOAM Running, Solving & CFD 6 July 16, 2008 08:03
Elements that limit the Courant number skabilan OpenFOAM Running, Solving & CFD 9 July 3, 2008 12:07
Has anyone successfully used transition modell..p2 PetrK CFX 12 May 26, 2006 16:27
