September 16, 2009, 02:38 |
RSM can not converge !?
For my geometry in FLUENT, when I choose standard/RNG/Realizable k-e model, the iiteration can converge. BUT when I choose RSM, the iteration can NOT converge. It happens some errors after several iterations(less than 10).
How to fix the problem? Thanks |
September 16, 2009, 11:59 |
Rep Power: 17 |
This is a common problem with the RSM model - the Reynolds stress equations are highly coupled, making convergence difficult. Try reducing under-relaxation factors and the courant number. If those don't help, I've had some luck with multi-gridding and residual smoothing.
Most likely though, if UR factors and courant number don't fix the problem, then you should make sure your grid is sufficiently fine and the cell qualities are excellent. The RSM model is finicky. |
Laminar doesn't converge; Turbulent models do? | Amit | FLUENT | 11 | April 23, 2015 22:55 |
RSM do not converge | Eric Wang | CFX | 3 | January 13, 2009 03:31 |
HELP !In relaxtion factor converge is taken or not | MANOJ KUMAR | FLUENT | 5 | September 22, 2005 04:16 |
Converge problem for multiphase flow | Jen | FLUENT | 2 | September 8, 2005 08:47 |
Converge problem for multiphase flow | Jen | FLUENT | 4 | July 20, 2005 16:52 |
