September 16, 2009, 18:29 |
Mapping Zones or Surfaces?!?
James S.
I am trying to model a helically enhanced tube in fluent and I am trying to get away from modeling the whole length of the pipe to get the fully developed flow and the pressure drop. So, I am trying to work with only one 360 degree section of the pipe (one cycle of the helix). What I cant figure out is how to run the problem with a uniform velocity profile at the inlet, obtain a solution at the exit, and then map the solution at the exit to the inlet of a new run and then run the solution again. I would repeat this procedure until i felt the flow was fully developed in the solution. So, I am trying to map the exit solution to the inlet of a new run. Does anyone know how to do this or where I would begin. I have been all through Fluent's manual and I just cant seem to find the solution. Although, some of the things that I came across I did not fully understand.
Thanks for reading! |
mapping fluent |
Skipping Zones | 1337Hal | FLUENT | 1 | June 27, 2022 09:33 |
Importing or Creating 2D Flat Surfaces into CFX | Sam | CFX | 5 | March 30, 2013 11:11 |
Faceted surfaces in ICEM | Chriss | Main CFD Forum | 1 | May 6, 2008 15:18 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
Surfaces | Mark | FLUENT | 2 | February 9, 2004 10:41 |
