Writing Fluent Journal files Using TUI commands.
Old   September 7, 2019, 05:47
Wink Writing Fluent Journal files Using TUI commands.
Farid Ahmed Rakib
Farid2817 is on a distinguished road
I am facing problems while writing the results using ANSYS Fluent TUI commands. Please go through the description section and attached images, please?
I was trying to extract result for wall_fuel_rod only like temperature velocity etc. However (please see the attached images), when I have entered the name of my desired surface ( wall_fuel_rod), it is demanding another surface which I do not want to add, so I pressed "Enter" button and it wants other parameters. I went through all the commands and found the result. But I need to make all the commands in a line like in a Fluent Journal file ( consisted of TUI commands ). Hence I tried but it shows error in surface (2) while I do not want to extract anything for another surface. In that case what should be my TUI commands or how can I fix the issue as I need to run the Fluent Journal file using MATLAB for Uncertainty Quantification.
Thank you.
Farid2817 is offline   Reply With Quote
Old   September 8, 2019, 03:18
Lucky
To end a list you have to give the empty argument which is: ()
e.g.
blah blah blah "wall_fuel_rod" () blah blah blah blah blah
Also, there are no pictures... Funny, your problem didn't require any images to solve...
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 12:38
journal files and SCHEME Hugo FLUENT 2 October 26, 2017 09:25
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Problem Reading Fluent Files. Spy-k14 Tecplot 1 April 29, 2015 08:17
fluent journal files - speedup your postprocessing warlock FLUENT 0 March 8, 2006 23:36
