February 21, 2009, 23:16 |
Gambit Default Working Directory
How can I change the default working directory in Gambit? It is currently set to "./" which won't point to anything. Ideally, the default working directory would be the directory in which Gambit was opened in. I am using the Windows version of Gambit 2.3.16 with Hummingbird Exceed.
February 23, 2009, 08:12 |
Re: Gambit Default Working Directory
On Gambit Icon, right click, choose properties, and fill the path you want in "Execute in"
December 11, 2009, 21:41 |
Saeed Abbasi
Rep Power: 16 |
Hi, I have the same question. I did it, but it doesn't work.
December 13, 2009, 17:29 |
#4 | |
JT.Q
Rep Power: 16 |
u can change the default working directory on start panel.when u start G. ,u will see the panel as attachment 1,which in the working dictionary is the drive/folder you open,then press browse button and chose the drive by drives pull down menu(here e:/ as an example),then click the folder listed above(folder fluent as an ex.) as show in 2,then click ok button.you will see the working directory being changed as 3. also you can change the file name in session id box as a new tour,here 3d as an ex. or by pulling-down the session id list and chose an exist one to continue ur work. hope its helpful |
December 18, 2009, 22:53 |
Gambit 2.3.16, Xming or Exceed...
Rep Power: 16 |
Ok so I have windows 7, and I am trying to run Gambit I have Fluent 6.3.26 and it runs beautifully!!! but Gambit says the usual for many people:
Locating Exceed installation ... gambit failed in locating Exceed installation on your system. Please try to start Exceed manually before you run gambit. Starting C:\Fluent.Inc\gambit2.3.16\ntx86\gambit.exe -device open -id default_id2352 -new ... Gambit build SP2006032921. Warning : The current transport does not permit the attempted TCPIP connection. TRANS(SocketINETGetAddr): tnamebysocket() failed TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed TRANS(Open): transport open failed for tcp/bam-bam:0 Unable to open display SO I DOWNLOADED XMING WITH ALL ITS ADD-ONS AND STILL CANT GET GAMBIT TO WORK NOT EVEN WITH THE -DEV X11 COMMAND ON OPTIONS SO I WAS WONDERING IF ANYONE CAN HELP ME TO INSTALL XMING WITH GAMBIT OR TO TELL ME WICH VERSION OF EXCEED WILL WORK WITH MY GAMBIT ANY HELP WILL BE REALLY APRECCIATED!! I NEED GAMBIT TO COMPLETE MY INVESTIGATION THANX IN ADVANCE GUYS!! |
December 19, 2009, 07:13 |
Khaled
Rep Power: 17 |
what is your exceed version? because win vista and win 7 axcepte only hummingbird exceed 2008 version.
Display Modes | |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
ICEM working directory setting | Bogesz | CFX | 2 | October 8, 2008 08:45 |
Star-CCM+ Set Working Directory | Bart | Siemens | 1 | September 1, 2005 02:01 |
setting the working directory | Jiri Novak | FLUENT | 4 | April 24, 2005 09:13 |
GAMBIT default parameters?? | JB | FLUENT | 3 | January 28, 2005 09:50 |
