Home > Forums > FLUENT
Opperating pressure?
Old   September 27, 2009, 14:06
Default Opperating pressure?
Jonny
Jonny6001 is on a distinguished road
Hello, hopefully just a quick, simple question.
What exactly is the user defined opperating pressure used for? Does it only get used for absolute values of pressures in the results relative to the opperating pressure? Or does it actually affect the results of a solution?
I hope you understand what I mean.
Regards
Jonny6001 is offline   Reply With Quote
Old   September 27, 2009, 17:36
Ivan
ivanbuz is on a distinguished road
is it possible to affect the properties of the fluid such as ideal gas? I am not sure.
ivanbuz is offline   Reply With Quote
Old   September 29, 2009, 20:55
herntan's Avatar
YH Tan
herntan is on a distinguished road
Operating pressure + Gauge pressure = Absolute pressure
u will have parameter on boundary condition which only let u input gauge pressure.
Operating pressure was default as atmosphere pressure.
Herntan,
Add Reputation if I am right
herntan is offline   Reply With Quote
Old   September 30, 2009, 02:45
Jonny
Thanks, that's what I was predicting.
But does it get used in any of the solution calculations directly, or just addedd on to the gauge pressure at the end to make the pressures in the results relative to your opperating pressure, rather than just being a local solution pressure
Old   September 30, 2009, 02:57
herntan's Avatar
YH Tan
Yes. Operating pressure does matter in the calculation. They will use it in every single calculation require pressure.
anyhow, just make sure ur parameter input to the simulation is correct.
Double check if the pressure u got is gauge pressure or absolute pressure.
Herntan,
Thread Tools
Trackbacks are On
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
