September 8, 2009, 04:35 |
If my solution is converged ?
Rep Power: 16 |
I want to use the time-dependant solver to get the steady state. And I also monitor some important parameters, such as temperature, vof...
After some iterations, I found these parameters almost do not change, but the residuals remains at a high value(10-2) and goes flat. I wonder if I my problem is converged ? The residula and monitor look like this > vof.JPGresidual.JPG |
September 9, 2009, 08:28 |
JP
Rep Power: 18 |
Residuals becoming flat may indicate:
1. Your solution has converged, or 2. This is the minimum residual possible with your current grid. For further reduction in residuals, you may have to refine or adapt the grid. |
September 9, 2009, 14:08 |
Sean Delfel
Rep Power: 16 |
Yeah, I agree with srjp. You're going to need to refine your grid. I would recommend plotting contours of mass imbalance (since your continuity residuals didn't converge) and refining where they are high.
-sean |
September 10, 2009, 01:39 |
you both wrong.
this is transient solution and if one decrease the time step the residuals will decrease too. you execute 1 ineration on 1 time step? |
September 10, 2009, 02:03 |
Maxime Perelli
Rep Power: 41 |
the continuity residuals are too high.
reduce your time step
In memory of my friend Hervé: CFD engineer & freerider |
September 10, 2009, 09:16 |
JP
Rep Power: 18 |
Sorry, I thought it was steady state simulation.
May be after frustration of seeing so many flat residuals !!! Agree with mAx on the timestep reduction. |
September 10, 2009, 11:00 |
Sean Delfel
Rep Power: 16 |
ditto.
-sean |
September 11, 2009, 02:51 |
Rep Power: 16 |
Yes, 1 interation on 1 time step at beginning, because I want save computation time. And then I increase the interations each time step, and the residuals also remain flat.
September 11, 2009, 03:39 |
#9 |
Maxime Perelli
Rep Power: 41 |
forget 1 iteration per time step
try the default settings, eg: 20 iterations per time step I would also recommend you to start your unsteady computation from a well converged steady solution
September 11, 2009, 17:46 |
#10 |
Ivan
Rep Power: 16 |
Most likely you are using a too big time-step. The time in your pictures is 2.4e4. Imagine if time step=1e-6, how many steps it will be....
September 16, 2009, 09:21 |
Character of success iteration???
#11 |
teguh hady
Rep Power: 17 |
Hello!!!
I'm a new user in FLUENT. I've read your Post. I wanna know what is the indication that we have success iteration?? I've thought that FLAT graph on the Residual graph is the indication!!! Am I wrong??? |
September 17, 2009, 04:07 |
#12 |
Rep Power: 16 |
I think when the we get converged solution, the residual will go flat. But at the same time, the residual should fulfill the criterion, such as 10e-4,10e-5...
September 17, 2009, 06:59 |
#13 |
Flat or not it is no matter. If iteration converged then it is. I think so.
Regards. |
September 28, 2009, 03:29 |
#14 |
teguh hady
Rep Power: 17 |
Is there an equation to prove it?? just to know how much convergence value!!!
September 29, 2009, 01:33 |
#15 |
there is navier-stokes equation.
and http://en.wikipedia.org/wiki/Residua...rical_analysis) regards. |
Solution converged, and then diverge again. | jrg | FLUENT | 2 | April 1, 2013 23:10 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Calculate a converged flow solution | kumar | FLUENT | 2 | May 24, 2007 01:33 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
converged solution or correct solution | SAM | FLUENT | 1 | October 12, 2004 15:38 |
