Animation Sequence in Fluent with unsteady state Condition
Hi there
Can anyone tell me how to create a video from fluent. I am running on 2ddp Unsteady State. I read the documentation from Fluent website on how to create a animation sequence and followed that. It created a .cxa file and numerous HMF files. Then I write a MPEG video from those files as told by Fluent Documentation. But all I get is a blank video. A video that plays for 2 mins but displays nothing. When I opened .cxa file in notepad and checked for any errors with HMF files but everything was perfect with those files. I asked fluent to write PPM files as well as METAFILE for Contours and saved them in 2 different folders. Both the files(PPM and METAFILE) gives a blank video. Can someone help me with this case. Thanks Krishna |
I think u have ur model show grid option open.
Try go view grid and change to grid display with outline only. then do the video again. |
Video from Fluent isn't very friendly
What I always did is to generate picture each time step, and then generate video from all the pictures. you can use solve/execute... and then TUI commands for setting and exporting pictures. http://www.fluent.com/about/news/new...00v9i2/a23.htm |
Hello!! And could you tell me how to generate the images in an efficient manner.
Thanks in advance. Daniel |
video from fluents
for this subject , you visit the (menu toolbar) : solve-animate-define and define that you need about. then iterate , and then click play back. by(ahomira6991@gmail.com) |
how to define animations?
I have defined in dispaly->graphics and animation and set contours and after that in animation->solution animation playback and then setup as the way tutorial was said but nothing dispalys.why? |
| All times are GMT -4. The time now is 15:06. |
