September 30, 2009, 10:52 |
Compressible flow over airfoil
s.k
Rep Power: 16 |
Hi
I have an airfoil mesh, and its overall boudary is set to velocity inlet. I want to run a compressible flow analysis, so i changed the boundary to pressure-far-field (in fluent). i tried to run the compressible problem based on the fluent tutorial (tut.3 from ansys) and inputted the same commands. But the iterations fail, with the message "amg solver error". Does anyone know how i can solve this problem? i have tried changing some of the solution conditions but i am getting very inaccurate resluts. thanks! |
October 1, 2009, 16:33 |
mangal
Rep Power: 16 |
1. Check mesh
2. Try changing the solver 3. Try relaxing URFs |
October 1, 2009, 19:07 |
ANIL
Rep Power: 17 |
check mesh for errors
do case check before iterating |
High speed compressible flow through pipe | Munni | Main CFD Forum | 6 | December 7, 2015 11:33 |
3-D Compressible Flow Boundary Conditions | Tyler | FLUENT | 4 | February 5, 2009 19:58 |
About the invisd flow around an airfoil | maximus | Main CFD Forum | 1 | July 16, 2005 15:04 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
