October 8, 2009, 00:27 |
Initializing a simulation.
Teymour
Rep Power: 16 |
Dear all,
I am working on modeling a wind turbine in a wind tunnel using SRF scheme. After my first set of simulations, I come up to this conclusion that in order to have a better idea about the wake behind the turbine I need to extend the region behind the turbine. I created the new mesh and want to initialize it with the results from my first simulations, but the problem is that, when I replace my new mesh with the older one (shorter tunnel) I should start my simulation from zero. I was wondering if there is any way so that I can initialize my new mesh with the results from the old cas. and dat. file. As I mentioned the only difference between old and new mesh is the extended part at the end of the channel. Right now after replacing the mesh, when I want to run the simulation,m FLUENT asks me to initialize problem at first. Thank you for your time and consideration and I am looking forward to hear from you. With regards Teymour |
Display Modes | |
Solar Radiation in OpenFOAM | plainstyle | OpenFOAM Running, Solving & CFD | 15 | July 8, 2014 04:43 |
FSI TWO-WAY SIMULATION | Smagmon | CFX | 1 | March 6, 2009 13:24 |
Continuous vs interrupted simulation | sega | OpenFOAM Running, Solving & CFD | 4 | November 3, 2008 14:29 |
Fire simulation using FDS from NIST | Jens | Main CFD Forum | 1 | January 22, 2004 01:53 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
