-   -   Velocity Contours (http://www.cfd-online.com/Forums/fluent/69069-velocity-contours.html)
sambayo October 11, 2009 05:27
Velocity Contours
if we have a 3D pipeline and there is a mixture flow of air and water and i want to make a cross section to see the velocity change through the pipeline how to do it ?
thank you
Laci October 12, 2009 02:48
thank you
If it you need a plane surface, create a plane: Surface/Plane (set 3 point coordinate) than Display/Contours/Velocity. Her choose the surface you created before.
Or you can use Display/Graphics and Animations/Sweep surface.
I hope I could help to you.
sambayo October 12, 2009 04:49
i will try it thank you for you help
