October 13, 2009, 07:18 |
problem in using MRF model
haamed mohajer
Rep Power: 16 |
Hi
we are analysing a wind turbine with Fluent, we tested 2 models for rotating turbines(MRF& moving walls for blades). But the results of MRF model is completely out of range while the results of moving wall model is near to desired range. we will appreciate you if you guide us. |
Display Modes | |
problem with UDF for (v2-f) turbulence model in fluent | artemiss1984 | Fluent UDF and Scheme Programming | 6 | January 17, 2014 05:50 |
problem of dynamic mesh for a piston model | pipin | Fluent UDF and Scheme Programming | 2 | August 2, 2010 14:35 |
A Problem with setting the time step in VOF model | Le | FLUENT | 2 | July 20, 2006 22:00 |
Non premixed model - combustion validation problem | David | FLUENT | 2 | October 24, 2003 10:06 |
Two phase Eulerian Model Problem | senthil | FLUENT | 5 | May 21, 2003 02:55 |
