-   FLUENT (
-   -   Are user-defined sources density weighted? (
tstorm October 14, 2009 12:47
Hi all,
Does FLUENT require that user-defined sources be density weighted? For example, the k source is Pk-epsilon. Would that be defined in a UDF as
source = Pk-epsilon
source = C_R(c,t)*(Pk-epsilon)
tez October 14, 2009 15:11
you don't have to include density in production term.
tstorm October 14, 2009 15:25
But it's included in the epsilon term? So,
source = Pk-rho*epsilon
tez October 14, 2009 15:57
Yes it is. I suggest you to go through the FLUENT Manual "Turbulence Modeling" chapter and look for k-epsilon or k-omega model to be clear. If you simply balance the units of these terms you will understand. "D(rho*k)/Dt" has the same dimension as "mu_t*S*S". Good luck.
