October 15, 2009, 00:36 |
about energy equation
Rep Power: 16 |
hi there,
I have known from the user guide that the energy equation has two froms(temperature and enthalpy form), And now I have energy source term of different form(also temperature and enthalpy form), I want Fluent to solve different form energy equation, what procedures need I do? thanks a lot |
October 15, 2009, 15:34 |
Payan
Rep Power: 16 |
If you want to include source term in energy equation,my experience tells that you should write a UDF to include a source term in energy equation,for better explanation read UDF manual.
October 15, 2009, 21:29 |
#3 | |
Rep Power: 16 |
but now I have two equal souce terms which have different form(temperature or enthalpy form), so I want to know what should I do except write a UDF to activate different form of energy equations? |
October 16, 2009, 01:52 |
Payan
Rep Power: 16 |
You can include every form of source term in Energy equation,Macro "C_H(c,t) " is enthalpy of cell and "C_T(c,t)" is temperature of cell and you can use theme in your source term UDF,Energy equation works with both of them and is already active,It is not matter that you use whitch of them(temp of enthalpy),But you should define your source term exactly.
UDF refers to user defined function and for writing udfs you should have a programming basis in C language and read udf manual(Chapter 1,2,3,4 at least),You should spend a little more time to achieve your goal! |
October 19, 2009, 10:44 |
#5 | |
Rep Power: 16 |
thank you for your reply! and your reply gives me big inspiration. but now I have another problem about the macro C_H_G, fluent shows the error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () would you help me!!! |
Display Modes | |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Need help:about energy equation in CFX | Stein | CFX | 4 | July 2, 2009 22:31 |
SIMPLE and energy equation convergence | Fabio | Main CFD Forum | 0 | June 1, 2007 06:06 |
question about energy equation | zhou | FLUENT | 0 | February 23, 2004 23:55 |
