time step and iterations in steady state problem using transient solver |
January 14, 2010, 06:08 |
Rep Power: 16 |
I am using the transient solver for a steady state problem. Whether the time step and iterations per time step can effect the final results ? I want to know if I can use a large time step and 1 iteration per time step to reach the steady state.
January 14, 2010, 21:19 |
YH Tan
Rep Power: 17 |
ur question answer can be vary from case to case.
If u understand what u trying to simulation, u should know how long it takes to have everything reach steady. for example, u got a simulation which happen very fast and ended in 1second, u should try to set ur time step 0.1 sec or less to see what happen in that 1 second. as u can see, its depend on ur simulation.
Herntan, Add Reputation if I am right |
January 15, 2010, 04:18 |
Svetlin Filipov
Rep Power: 17 |
Reach conversion criteria during iterations.... if the flow pattern does not change.... you can take this as a final solution
Display Modes | |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
