October 26, 2009, 11:07 |
Run Fluent in Linux
I am new to Linux and tried to install Fluent on it. I had done everything mentioned in the installation guide and the CFD-online forum as well but I am still unable to run it. For example, I first install the .sh file using sh command then added some lines in the .bash_profile file. I have installed everything in the home directory. But now, when I type fluent in the terminal window it says fluent is not a command. Can somebody pls help that where am I making a mistake or whats the problem? Regards |
October 26, 2009, 11:45 |
Wiebe Zoon
Hi Shamoon,
the fluent executable is probably not in your path. You can change the path to include the directory where fluent is found (search the internet on how to do this!) or type the fluent command from the command line including the full directory (something like ./fluent-6.3.26/Fluent.Inc/bin/fluent) Good luck! Wiebe. |
October 26, 2009, 12:06 |
Dear Zoon
The fluent executable is in my path however, its still not running. It should be noted that I am using fluent 6.2 not 6.3 |
October 26, 2009, 12:12 |
What about the liscence installation is it the same way as in windows
Fluent Linux and OS | mortain | FLUENT | 9 | September 15, 2009 13:10 |
Check FLUENT licenses in Linux | L3munoz | FLUENT | 3 | September 3, 2009 20:09 |
Fluent for linux | Patryk | FLUENT | 0 | July 20, 2009 20:04 |
Fluent Remote Simulation Facility Service (RSF) di | Rami | FLUENT | 2 | June 4, 2008 06:38 |
Running Fluent on Linux AMD machine | David Reinbold | FLUENT | 5 | September 21, 2001 18:08 |
