October 26, 2009, 19:30 |
Fogging / Mixing Problem
Hello All,
I am new to CFD so I don't have much experience in the field and I need help. For my research I am trying to model a vapor mixing with ambient air. The vapor is diesel based oil (used for thick fog generation) in gaseous phase which is coming out of 5x 1/16 inch diameter holes at 1050 deg. Fahrenheit and 1000 Pa gauge pressure. I need FLUENT to show me how it is mixing with the air (air entrainment), where the temperature of the vapor is 870 deg F and the fogoil to air ratio in terms of volume fraction and mass fraction. After doing some research, I found out that I can get a Volume fraction ratio if i use multi-phase model but I have to use single phase Multi-component model to obtain mass fraction ratio. So I am confused as to what model I should use and how to set the boundary conditions. If you have experience in this sort of simulation or modelling please help me out as I am under a little time crunch as well. |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
mixing plan problem | ravindra bankar | FLUENT | 2 | May 12, 2006 03:41 |
multiphase mixing Problem with MRF model in MixSim | Srinivas | FLUENT | 0 | October 17, 2005 06:35 |
HELP!: swimming pool flow problem | Tee | FLUENT | 1 | September 8, 2005 08:29 |
Mixing plane geometry definition | Hbet | FLUENT | 0 | January 18, 2002 07:16 |
