parallel
Dear all,
i have a computer using four processors, i want to run two model at same time, how i do them as first model use one processor and second model use of others? thanks a lot. |
Run two instances of Fluent. Start the first one normally, then for the second, run Fluent with the -t3 flag to create 3 threads, thereby using the other three processors.
thanks a lot.
But ensure that your two fluent instances are not using the same CPUs....
if your're running on a linux machine you can determine the process ids using "ps" command and then distribute the processes on the cpus with "taskset".... that's how I'm doing it. |
