November 6, 2009, 15:58 |
Compressible flow
hassan
Rep Power: 16 |
Hi guys,
I am modeling a converging diverging geometry, like all oyu know the nozzle-diffuser. it is a compressible flow of air. my BC is : pressure inlet: 3.18 atm (gauge total pressure), 1 atm (supersonic/gauge) and total temprature 417. (actually i set inlet mach number1.4 and i computed these condition by putting the ration of outlet to throat equal 2). pressure outlet : 1 atm and total temrature 300. my solver is pressure based, energy eq., vis : spalart. material air, density ideal gas. operating pre. eq. zero. under relaxation deafault, adapt gradient/ pressure with coarsen threshold 0 and refine 0.3. why it is diverging? thanks a lot. |
November 7, 2009, 04:05 |
JSM
Rep Power: 20 |
Converging the solution with pressure inlet and pressure outlet is difficult especially for compressible flow simulations. I don't know your geometry size and solver set up. Just try these suggestion. If possible try with mass flow inlet boundary condition or gradually increase the inlet pressure to your desired value.
With regards, JSM |
November 8, 2009, 09:44 |
#3 | |
hassan
Rep Power: 16 |
Hi, Thanks for your reply. Goemetry: 6 cm length and 8 mm height. I am trying these methods, it is better now, but not perfect. |
November 10, 2009, 19:34 |
Chris
Rep Power: 16 |
Try extending your outlet boundary past the end of the diffuser. When you do this, stretch the grid. Also, is your y+ in the correct range for the S-A model?
Compressible Fluid Flow in COMSOL Multiphysics | BBG | COMSOL | 1 | November 19, 2008 14:05 |
Mass flow inlet compressible flow | richard | FLUENT | 2 | June 1, 2008 11:44 |
compressible flow algorithm | ztdep | Main CFD Forum | 4 | April 27, 2008 20:41 |
free on line compressible flow book | genick bar-meir | Main CFD Forum | 4 | December 5, 2005 00:25 |
Solving unsteady compressible low speed flow | atit | Main CFD Forum | 8 | July 31, 2000 13:19 |
