-   -   How create GOOD quality animation in Fluent ? (http://www.cfd-online.com/Forums/fluent/69890-how-create-good-quality-animation-fluent.html)
maziboss November 8, 2009 12:52
Hello :)
I created mpg files but the quality is terrible :( Do You have any ideas how to create much better animation in fluent ? Here is my simple...
Animation
I want to create mpeg files in higher resolution...
O.D.Y. November 8, 2009 13:38
Hi there,
do you necessarily need mpgs?
Because I'm using PPM images and create animated-gifs with gimp (open source graphic program) and they actually appear to be very good.
ageorg November 9, 2009 00:58
Try using tecplot 360 that directly creates animations of high quality!
Philipov November 9, 2009 03:26
Only Tecplot or other software like Fieldview
srjp November 9, 2009 05:03
If you maximize the image screen before you make the movie, I found that the movie size is bigger and the clarity also better. Make the movie with hmf files instead of ppm (this gives more control on the view, size etc)
snow November 9, 2009 08:43
Export jpeg files with desired resolution and convert to movie using ffmpeg.
herntan November 9, 2009 22:48
U need to adjust the hardcopy version of before u create MPEG.
For example, after u done the simulation u go to playback.
the playback have a selection on hardcopy and mpeg.
U click into hardcopy, set it as JPEG, and give damn high resolution for it , such as 1600x1200.
after that, u choose mpeg again in playback window.
now u will create a mpeg with 1600x1200 resolution.
i doing 800x600 resolution last time by using this steps, its working fine for me.
Take a try.
maziboss November 22, 2009 06:57
Take a try.
You have right but i think the mpeg still has bad quality... :( I'll be write to ppg images and create from this files movie. Thanks for all !
