global variable in udf
Old   November 21, 2009, 11:03
Default global variable in udf
MOHSEN Zendehbad
mohsen zendehbad is on a distinguished road
i am writing a DEFINE_SOURCE, how can i define a global variable in udf whose value doesn't reset by the repetition of the udf for each cell in the zone.
mohsen zendehbad is offline   Reply With Quote
Old   November 21, 2009, 14:16
Herman
enry is on a distinguished road
when you need a global variable you have to define that variable OUTSIDE of any single function, so the variable is visible to all functions within a UDF source file .I past to you a text that you can find in UDF guide.
Global variables are variables that are defined outside of any single function and are
visible to all function(s) within a UDF source file. Global variables can also be used
by other functions outside of the source file unless they are declared as static (see
Section A.5.3: Static Variables). Global variables are typically declared at the beginning
of a file, after preprocessor directives as in
#include "udf.h"
real volume; /* real variable named volume is declared globally */
DEFINE_ADJUST(compute_volume, domain)
/* code that computes volume of some zone */
volume = ....
Otherwise, If you have a global variable that is declared in one source code file, but a function in another source file needs to use it, then it must be defined in the other source file as an EXTERNAL variable.
See also:
http://hpce.iitm.ac.in/website/Manua...help/index.htm
enry is offline   Reply With Quote
Old   November 22, 2009, 05:30
MOHSEN Zendehbad
DEAR ENRY:
thank you for your swift response.
MOHSEN
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
