November 21, 2009, 18:21 |
asking usage of velocity inlet
teguh hady
Rep Power: 17 |
Hi All
I read tutorial on http://courses.cit.cornell.edu/fluent/plate/step3.htm. I see something odd. The BC of Inflow is Velocity inlet & The fluid is ideal gas. I think Velocity inlet is used for incompressible flow. Can you explain it?? Thank You, teguh
Now Or Never!!! Last edited by teguhtf; November 21, 2009 at 19:57. Reason: Correcting |
November 22, 2009, 06:32 |
Herman
Rep Power: 16 |
velocity inlet is the B.C. of inflow, as you write. Why do you think that condition as incompressible flow? I think that condition only as a condition that you can impose. |
November 22, 2009, 09:20 |
teguh hady
Rep Power: 17 |
Thanks for replying. I have run that simulation. It run completely. But there is warning on FLUENT when I choose velocity inlet as inflow. In FLUENT manuals, compressible flow can be solved by using mass flow inlet or like pressure inlet. I'm afraid if i impose the boundary, there will be incorrect result. I see if compressible flow can be assumed as incompressible flow if the velocity < 0.3 Mach. However there is still error, isn't it?? teguh
Now Or Never!!! |
November 22, 2009, 10:28 |
Herman
Rep Power: 16 |
As far as I know, I don't think that the error is due to velocity inlet BC.
I try to solve a simple plane plate imposing supersonic velocity inlet, and fluent doesn't report any error (even if the result may be wrong....) . What tipe of error fluent report for your problem? |
November 23, 2009, 06:39 |
teguh hady
Rep Power: 17 |
Well, There is warning when i choose Velocity Inlet as inlet BC. I think it can cause error on my simulation. Am I wrong??
For case high mach number. There is option pressure far field or pressure inlet (I just read some tutorials on studentFLUENT). Is it OK if we use velocity inlet to simulate compressible flow for high mach number?? Can you tell me your reference?? Thanks for helping teguh
Now Or Never!!! Last edited by teguhtf; November 23, 2009 at 06:41. Reason: correcting |
November 24, 2009, 03:47 |
Herman
Rep Power: 16 |
Here there are all fluent guide and manual. Try to visit it.
http://hpce.iitm.ac.in/website/Manua...help/index.htm There are also some tutorials. |
nonuniform velocity at the inlet | sambatra | OpenFOAM Running, Solving & CFD | 5 | June 17, 2014 17:39 |
velocity inlet vs pressure inlet | cheong | FLUENT | 6 | April 9, 2011 03:07 |
Create hemisphere like velocity profile at inlet | Nelson | Main CFD Forum | 3 | July 27, 2005 12:05 |
UDF problem : inlet velocity in cyl. coord. system | Jongdae Kim | FLUENT | 0 | June 15, 2004 11:21 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
