November 27, 2009, 11:44 |
Airflow over car/spoiler
Rich
Rep Power: 16 |
i want to set up my first Fluent Project. It's an analysis of flow over a car and spoiler. i will list what exactly i am doing and i would be nice if someone could point out errors and mistakes, or suggestions to make it better. i basically have a car body without spoiler and the spoiler as mesh (and then inlet, outlet, symmetry plane etc.)
2. solution initialize. there i pick the inlet and initialize it. 3. under iterations i type in 200 4. let fluent calculate and wait until it converges 5. under post processing i plot the static pressures over the cars surface and under xy plot the cp over the carbody and spoiler.
2. that area size i use under reference values-area. 3. i disable the converge option under residuals and just let fluent calculate 500 iterations 4. what i noticed: e.g. for 200 iterations i get an cL= -0.042 and for 500 iterations cL= -0.027. i am not sure now how to interpret the difference in cL values, i guess the solution didn't converge yet? and cL decreases until it does? does anyone have experience how many iterations i should use?
cL = (Lcar + Lspoiler) / (0.5*density*speed^2*Area) with Area = projected Area of the car onto the xy plane? |
December 2, 2009, 12:18 |
Joel
Rep Power: 16 |
What I've been told in the past is that for a converged solution you usually want to change the convergence criteria from .001 to .000001. This may be the reason your Cl value is still changing. This also will eliminate needing to guess how many iterations you need since it will stop once it reaches that convergence criteria.
December 2, 2009, 12:47 |
Rich
Rep Power: 16 |
yep thanks. i let it run for 1500 iterations and cl became quite constant.
my only problem left now is how to calculate the lift of the whole car in fluent. |
Floworks for simulation of airflow in large rooms. | kajaken | FloEFD, FloWorks & FloTHERM | 1 | October 28, 2008 13:58 |
How to simulate the fan driven by the airflow? | Jason | FLUENT | 2 | April 17, 2008 15:56 |
how to define the external airflow b.c | frank | FLUENT | 3 | July 26, 2005 09:57 |
how to treat both indoor and outdoor airflow | Frank | Main CFD Forum | 1 | June 21, 2005 00:57 |
modelling airflow through an inlet restrictor on a four stroke engine | mike ede | Main CFD Forum | 0 | October 8, 1999 09:06 |
