Import problem in fluent GRD file
Old   November 28, 2009, 15:13
Default Import problem in fluent GRD file
sujan dasmahapatra
sujan.dasmahapatra is on a distinguished road
Dear Friends
I am new to Fluent-Gambit. I am doing the tutorials of mixing elbow where I am creating mesh for mixing elbow pipes. The mesh is created using fluent 4 solver setting.
Now I exported the mesh as elbow.GRD but when I am trying to import that file into fluent its not loading the grid giving errors.
Error: sopeninputfile: unable to open pipe for input
Error Object: "| utility fl42seg D:\CFD\Fluent\Projects\ELBOW\ExportedFromGambit\Mi xingElow.GRD"
Error: Error reading "| utility fl42seg D:\CFD\Fluent\Projects\ELBOW\ExportedFromGambit\Mi xingElow.GRD".
Error Object: #f
Error: %repair-face-handedness: invalid grid.
Error Object: ()
Reading "| utility fl42seg D:\CFD\Fluent\Projects\ELBOW\ExportedFromGambit\Mi xingElow.GRD"...
Error Object: #f
Error Object: ()
what am I missing in this.
Any help would be appreciated.
Thanks
sujan
sujan.dasmahapatra is offline   Reply With Quote
Old   November 29, 2009, 05:12
mach
mach13 is on a distinguished road
Hi
If my memory is right I think, the elbow is 2D. Then while exporting mesh , be sure to select the 2D option button.
Regards
mach13 is offline   Reply With Quote
Old   November 30, 2009, 17:21
audrich is on a distinguished road
Try exporting the design as a MSH format rather than GRD, and check the "export as 2D" box.
audrich is offline   Reply With Quote
Old   March 23, 2010, 23:22
Default Can you help me
hassan
hassan79 is on a distinguished road
Q1 Any one do for me mesh file (mesh or dbs I want to calculate surface Nusselt number in for downstream ( near the wall )in expansion pipe with turbulent fluid flow the dimension
Small pipe UN heated
Diameter 0.0254 m and width 1.2192m
Big pipe heated
Diameter 0.09525 m and width 1.7145m
Q2 in fluent which turbulent model suitable to my case
thank you
hassanhayawi@gmail.com
hassan79 is offline   Reply With Quote
problem with reading my prePDF file into fluent James Willie FLUENT 9 March 10, 2012 02:51
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
no spacing in gambit fluent 4 grd file zonexo FLUENT 0 May 19, 2006 11:47
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
