RP_Set_List_of_Integer
Old   December 2, 2009, 10:41
Exclamation RP_Set_List_of_Integer
Illya Shevchuk
linch is on a distinguished road
Hi everyone,
I have a problem with using RP_Set_List_of_Integer macro. Does somebody know how does it work?
For example I define a global variable <testlist> in the Fluent text interface or in a scheme file first:
(rp-var-define 'testlist '() 'integer-list #f)
Next I write a simple UDF to test the macro:
DEFINE_ON_DEMAND(demand_test_list_set)
int a=10, b=20, c=30;
    RP_Set_List_of_Integer("testlist", &a, 1);
    RP_Set_List_of_Integer("testlist", &b, 2);
    RP_Set_List_of_Integer("testlist", &c, 3);
    Message("Length of the list: %i\n",RP_Get_List_Length("testlist"));
    Message("1st element of the list: %i\n",RP_Get_List_Ref_Int("testlist",0));
    Message("2nd element of the list: %i\n",RP_Get_List_Ref_Int("testlist",1));
    Message("3rd element of the list: %i\n",RP_Get_List_Ref_Int("testlist",2));
It works almost perfectly, with an only exception, that fluent returns the elements in an inverse order:
Length of the list: 3
1st element of the list: 30
2nd element of the list: 20
3rd element of the list: 10
It's a kind of strange, but I can live with it.
But if I pass the &a-pointer twice (a.e. if I want the third element of the list to be the same as the 1st):
    RP_Set_List_of_Integer("testlist", &a, 3);
it doesn't work properly. What I get is:
1st element of the list: 10
2nd element of the list: -1213829304
3rd element of the list: -1214887304
Why? What's the problem?
I went on trying and it seems not to work with arrays also:
int d[3];
    d[0]=10;
    d[1]=20;
    d[2]=30;
    RP_Set_List_of_Integer("testlist", d, 1);
    RP_Set_List_of_Integer("testlist", (d+1), 2);
    RP_Set_List_of_Integer("testlist", (d+2), 3);
The result looks similar to the previous example.
Can somebody please help me and tell me, how to use the RP_Set_List_of_Integer macro properly?
I need to store some arrays globally and as I want to do it anytime I want, I can not use the DEFINE_RW_FILE macro. So, the only way I see is to store them as RP-variables.
I would be grateful if you had some advices for me.
linch is offline   Reply With Quote
