November 29, 2009, 17:56 |
Interior BC option does not appear for MRF
I am performing MRF calculations. In Gambit, I notify the interface between rotating and non-rotating fluid regions as a wall and when reading into FLUENT 6.3 - i tried converting the interface wall BC to interior BC type. However, I noticed that when trying to do so, no "interior" BC type appeared on the right side panel in Boundary conditions. I am not sure how to convert my interface from wall to interior? If someone has faced similar problems kindly help me out. Regards, CFDtoy |
November 30, 2009, 01:03 |
Maxime Perelli
Rep Power: 41 |
the interfaces should be set as INTERFACE.
Then in fluent: --> define/interfaces, and choose the pair of interfaces
In memory of my friend Hervé: CFD engineer & freerider |
November 30, 2009, 09:48 |
MRF bc
Hi Max,
For MRF Shouldnt the interface inside the domain be just interior (according to Fluent manual). According to your recommendation, should I choose 2 interfaces while defining them in Gambit? I do not see the pair of interfaces option in Fluent for the selected face? The Fluent tutorials suggest that we use any BC while creating the interface in Gambit. For example, it could be a wall in Gambit options and then be converted in Fluent from Wall to interior? Does this part not supposed to work? Thanks for your input. CFDtoy |
December 2, 2009, 02:31 |
Maxime Perelli
Rep Power: 41 |
Sorry I mixed MRF and sliding Mesh.
Forgot what I previously said about interfaces.
December 3, 2009, 13:28 |
MRF Fluent case - blower.msh?
Hi all,
Can someone provide me with the sample case (i guess its blower.msh) that Fluent uses in tutorial for explaining MRF set up? I would like to know how to set up a MRF case starting from generating mesh using Gambit and assigning proper boundary conditions. Thanks. CFDtoy |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
