UDF access wall heat fluxes cid[]
Hallo,
I try to compute the total heat flux [W] from a wall to fluid inside a DEFINE_HEAT_FLUX macro. Is this the right way to do it? begin_f_loop q_solid2fluid += area*(cid[0]+cid[1]*C_T(c0,t0)-cid[2]*F_T(f,t)-cid[3]*pow(F_T(f,t),4)); end_f_loop In principle this q_solid2fluid should be the same value than the one under Report/Fluxes/Total Heat Transfer Rate, that it is the value I am looking for, but i don't get it. I appreaciate any comment. Thanks. icaro |
