Heat Transfer Boundary Conditions
Hello, I'm confused with the heat transfer calculation at boundaries, and hope someone could kindly clarify that for me:
I'm simulating a fluid flow in a nozzle, and need to specify a convective heat transfer BC at the nozzle wall in the form of: -k_fluid * dT/dn = h_cw*(T-T_cw), where cw stands for cooling water, and I can specify the value of h_cw and T_cw. I saw this BC in a paper, but don't know how to implement it in Fluent. My questions are: 1. how would Fluent calculate the heat flux from the fluid to the wall in this case? 2. do I just input h_cw and T_cw in the convective tab of the wall BC panel, or, 3. do I need to write a UDF with DEFINE_HEAT_FLUX? if this UDF is needed, how should I put it? something like: cid[0] = -k*C_T_G(c,t)? I'm really troubled with this problem, would greatly appreciate any help or hint. Thank you! ying |
| All times are GMT -4. The time now is 10:12. |
