iterate from command line
Like Tree6Likes
  • 2 Post By coglione
  • 4 Post By AnjaMiehe
Old   December 9, 2009, 10:24
Default iterate from command line
Jouke de Baar
jack1980 is on a distinguished road
Hi! For a VOF unsteady problem I can choose to: solve/iterate/ and enter, for example, time step = 0.1 s and number of time steps = 10.
Now, I would like to do this from the command line (to set up an inputfile and run simulation from batch mode). However, in the command line menu, if I chose solve/iterate this is a different command that will only ask for the number of iterations.
Question: What is the correct command line input for time step iteration?
Thanks!
jack1980 is offline   Reply With Quote
Old   December 10, 2009, 03:06
Max
coglione is on a distinguished road
Hello jouke,
for transient runs use solve/dual-time-iterate
cheers
appie and hamed100 like this.
coglione is offline   Reply With Quote
Old   December 10, 2009, 07:20
Jouke de Baar
Thanks for giving the correct command. However I still run into trouble. What I'm trying to do is write a simple inputfile as in Fluent User's Guide 1.3.1. It looks like this:
=== inputfile ===
rcd broken_dam_03.cas
solve/dual-time-iterate 9 20
wcd test.cas
exit
yes
When I run this sequence of commands from the command line in Fluent it works fine. However, when I run this inputfile from batch, the outputfile gives several errors, the first one being:
Reading "broken_dam_03.dat"...
Done.
invalid command [
Error: eval: unbound variable
Error Object: 20
Invalid integer.
Number of iterations per time step [20]
What could be wrong?
Old   December 10, 2009, 08:36
saeed
saeed is on a distinguished road
hi
i run PEM fuel cell in fluent but resive an error:
Error:floating point;invalid number
please help me!
saeed is offline   Reply With Quote
Old   December 10, 2009, 09:55
Anja Miehe
AnjaMiehe is on a distinguished road
=== inputfile ===
wcd test.cas
exit
yes
Done.
invalid command [
Error Object: 20
Invalid integer.
Hey,
I found a paper http://www.google.de/url?sa=t&source...a_Yutzd4RAyo4A (language: german) saying the command is:
 /solve/dual-time-iterate [number-of-timesteps] [max-number-of-iterations-per-time-step]
where everything in the brackets including the brackets has to be replaced by a number. I tried it and it works.
Hope, it works for you too
arsenis, kemin, lev and 1 others like this.
AnjaMiehe is offline   Reply With Quote
Old   July 16, 2010, 01:32
Dokeun, Hwang
dokeun is on a distinguished road
Dear AnjaMiehe
Thank you so much~ That's what I'm looking for solving my prob
dokeun is offline   Reply With Quote
Old   July 16, 2010, 10:15
Chris
Chris D is on a distinguished road
For the sake of posterity, you might have a problem if you write a script in windows and run it in unix/linux. The reason is that each os uses a different end of line character, so fluent will have some problem when it tries to read your script.
To see if this is your problem, you can open your script with a text editor (e.g., vi) and it will display some message at the bottom if it is in dos format. This took me an embarassingly long time to figure out, so hopefully I can save someone else the trouble!
The fix is to either
1) Write your script in linux with your favorite text editor, or...
2) Run the command dos2unix [input_file] to convert from dos format to unix/linux format.
Chris D is offline   Reply With Quote
Old   February 28, 2011, 14:27
Adam Arvay
aarvay is on a distinguished road
Gonna bump this old thread to say thanks for this. Typing in the individual commands worked fine, but once i tried loading the journal file I kept getting weirdness and errors such as
]nvalid command [
Doing the conversion with dos2unix fixed it. I had been using windows based notepad to write my script and it ran fine on my windows based fluent setup, but once i uploaded it to our unix cluster, it gave issues. So thanks again.
aarvay is offline   Reply With Quote
floating point error when starting to iterate Ralf Schmidt FLUENT 1 June 2, 2006 06:00
Can not Iterate this UDF mike FLUENT 3 November 23, 2005 19:26
Iterate command is not showing up Josh FLUENT 2 November 7, 2005 10:38
Fluent - Iterate Command Harish FLUENT 5 April 12, 2005 03:30
Solution won't iterate ?!?!? greg FLUENT 2 November 19, 2003 13:31
