-   FLUENT (
-   -   Fluent 12.0 help (
jkal December 14, 2009 19:14
Fluent 12.0 help
I am learning to use Fluent but I'm having some trouble. To start I want to just look at flow in a channel (2 side walls, an inlet and outlet). I was able to create a 2D rectangle by adding four points into 4 lines and finally a surface from edges. I then made 3 'named selections', wall, inlet, and outlet. I am able to create a mesh but my issues start when I try setting boundary conditions. The named selections I created aren't listed. What am I doing wrong?
Thanks in advanced
Irshad22 December 19, 2009 13:04
While applying boundary conditions you need change name (optional) but need to use apply button for each case. U can find the name and types in the table of zones.
