Home > Forums > FLUENT
Multi-fluid and multi-phase modeling
Old   December 15, 2009, 04:20
Default Multi-fluid and multi-phase modeling
anonymous
CFDUSER-A is on a distinguished road
Is it possible to model a system consisting of more than one fluid and use a multiphase model in the same time?
Everytime i activate the multiphase models, a primary phase has to be defined and it exists in all the fluid sections. How can i get around that?
one section of the system has a velocity-inlet/oulet and the other section consists of walls shaped as a pipe that loops. Each section contains a completely different fluid.
please enlighten me,
Thank you
CFDUSER-A is offline   Reply With Quote
Old   December 15, 2009, 10:57
Default different fluid in domains
CFDtoy
CFDtoy is on a distinguished road
Multiple fluids existing in the system is the basic essence of MP flows. For different regions working with different fluids, try patching the regions initially with different fluid fractions and make sure the bc for each section has vf = 1 for fluid that needs to be circulated and other fluid 0. For multiphase cases, there has to be a primary and secondary phase to define interactions. This is how mp cases are set up numerically.
/CFDtoy
Thank you
CFDtoy is offline   Reply With Quote
Old   December 16, 2009, 14:40
anonymous
Thank you for the reply, i tried the exact thing you wrote earlier but my system diverges rapidly. Once i patch the fluid domain problems start and the iterations stop converging. Do you have any suggestions on what to do once that occurs.
Thanks,
Old   December 16, 2009, 15:00
Default runs
CFDtoy
Solution convergence/divergence is based on your set up. For example, you could have patched a domain with fluid "a" but at the boundaries may have insisted on having 0 fraction of a => there is fluid b = 1-a entering a domain filled with 'a' and then problem becomes more of adjusting your solver controls.
Make sure there is good inflow and outflow conditions specified.
I would say just be very careful with your boundary conditions for these systems where you patch..do not let fluid a and b mix rapidly ..i.e. adjust time step / courant number those kind of things i would pay attention once the system has been set up well.
/CFDtoy
Thanks,
Thread Tools
Trackbacks are On
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
multi fluid v4.08 star CD-adapco 0 February 17, 2009 21:41
Multi phase heat exchange simulation. JP CFX 1 May 26, 2008 05:22
Multi Fluid david FLUENT 0 March 8, 2007 09:36
Eulerian Multi Fluid Model CFDtoy Main CFD Forum 3 January 25, 2005 14:44
