restricting path-line xy-plots to specific axes ranges
Old   December 16, 2009, 19:58
Default restricting path-line xy-plots to specific axes ranges
Jon Madison
j0nnymad is on a distinguished road
I have successfully run fluid flow simulations through various geometries of interest and am interested in ascertaining the pathlength of flow through the structures. I can use xy plot in the pathlines menu but would like to write data to a text file over only a specific range of the dependent variable (in my case y-coordinate). Although I can restrict the fluent generated window plots to the axes limits of my choice, whenever I try to "write to file" it writes ALL pathlength data for all y coordinates. Which are very LARGE files that are difficult to work with. I'm using FLUENT 6.3.26. Any assistance would be greatly appreciated.
j0nnymad is offline   Reply With Quote
axes, pathlines, ranges, xyplot
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
