Flow through a inline cylinder array
Old   December 16, 2009, 11:18
Default Flow through a inline cylinder array
Jonathan
new2cfd is on a distinguished road
Hi all,
First off I am new to cfd and this forum. My question pertains to Fluent and cfd in general I believe. I have been working on the problem of trying to resolve friction factors and Nusselt number for various inline tube array with 100<Re<1500. I have been working on the problem for some time with very little success. I have tried 2D single half cylinder with periodicity and symmetry, half tube arrays with 10 or more tubes with velocity inlets and pressure outlets significant inlet and exit lengths, and half tubes on top and bottom of a row of full tubes. The problem is the friction factor is not even close to experimental data. I have tried laminar, ke, ko Re stress, and LES all steady and unsteady. I have yet to find a cfd paper reporting these value and tout flow structure but not engineering values. Can these values be accurately resolved to 10-20% error, and if so can you give me some guidance/references for this?
Thanks
Jonathan
new2cfd is offline   Reply With Quote
Old   December 16, 2009, 19:47
karine
thecfduser is on a distinguished road
Hi
1-are u sure that ure geometry is 2D???? (i mean the geometry used to get experimental data)
2-are u including buoancy effects????
3- Avoid symetrical and peridocal boundaries: ure geometry is symetrical, but not the flow, specially that u have buoyancy effetcs. I think is is the major problem....
4-Laminar solver and LES in 2D will not necesseraly give real results.
Regards
thecfduser is offline   Reply With Quote
tube arrays cylinder 2d
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Simulation Flow Around cylinder 3D Jwolf CFX 19 November 25, 2009 14:21
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 14:32
axial flow around a cylinder -heat transfer model? Ralf Schmidt Main CFD Forum 1 March 21, 2006 08:54
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
