Boundary conditions
Old   December 17, 2009, 12:01
Default Boundary conditions
SimoneTecnoil is on a distinguished road
Hi to all....i have a problem!! I have water flowing in a pipe with several changes of section. The water has a pressure of 10 bar and a flow rate of 2kg/s in the input section. I do not understand how to set both of these data in the boundary conditions. Can you help me?
SimoneTecnoil is offline   Reply With Quote
Old   December 18, 2009, 07:54
Peter Watson
Maxtor is on a distinguished road
Questions this fundamental on the use of any CFD code are best resolved by taking the appropriate training course.
Maxtor is offline   Reply With Quote
Old   December 19, 2009, 11:44
Irshad
Irshad22 is on a distinguished road
go to the zones i.e. third option of operation in Gambit. There you can go for assigining of boundary types not the values. Values will be given in Fluent. For reference Go through the tutorials provided by fluent.
Irshad22 is offline   Reply With Quote
Old   December 20, 2009, 09:30
bob12 is on a distinguished road
ciao simone
per le condizioni al contorno le devi specificare in Gambit o il software per la mesh. Poi in Fluent puoi modificare sia la condizione al contorno che impostare i valori specifici per la soluzione del problema a secondo del modello.
bob12 is offline   Reply With Quote
Old   December 22, 2009, 03:34
Ok .... I'll try to explain better! I have no problems in general in setting the boundary conditions ....I have to calculate the pressure drop in a nozzle. I know the incoming water pressure, its temperature and flow rate. I want to know the speed in output and especially the loss of pressure in the nozzle when the inlet pressure is 10 bar. Now ... I'm confusing between operating conditions and boundary conditions. I do not know the exit pressure .... but I would use "pressure outlet" on the output section because I know that is more accurate ... and what I put as "gauge pressure" in the outlet? I do not know! Input I want to use "mass flow inlet" and here there are no problems. But the pressure of 10 bar where you put it? In operating conditions? HELP
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
Problems with boundary conditions for a lowRekOmegaSST turbulence model cfdmarkus OpenFOAM Running, Solving & CFD 16 November 14, 2011 04:44
Pressure boundary conditions Lionel S. Main CFD Forum 1 August 24, 2007 18:03
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
