Home > Forums > FLUENT
flow over a cylinder 2D
Old   March 10, 2010, 17:52
karine
thecfduser is on a distinguished road
U can do the mean values on Matlab (or excel)
If u want to have the means all over the domain, iterate again in Fluent for 1 period of time and dont forget to put yes for data sampling in the iterate menu
thecfduser is offline   Reply With Quote
Old   March 10, 2010, 18:01
Behrang Asgharian
behrang2009 is on a distinguished road
Hi
Thanks. The matlab or excel choice work good.
After checking the data sampling in the iterate menu. Where exactly should we go to after the iteration is over?
behrang2009 is offline   Reply With Quote
Old   March 10, 2010, 20:13
karine
AFter u go to plotxy or display contours menus. U choose Unsteady statistics .
( if ure flow is stationnary, i think it is better for u to do the means values over 4-5 periods....)
Old   March 10, 2010, 20:26
Behrang Asgharian
Thanks a lot
Old   March 24, 2010, 19:34
Behrang Asgharian
Hi Again!
How can I initialize the domain using UDF? I mean, for example: I am modeling acoustic oscillating flow which is inherently unsteady so I need to initialize it and after some time it produces sinusoidal curves for velocity and pressure. the problem is that I have to wait for the case to reach that quasi steady state (I mean oscillating with constant frequency and constant amplitudes). If there is a way to initialize with the theoretical sinusoidal pressure distribution throughout the domain, it will definitely reach the quasi steady state faster and that's time-saving. Any suggestions?
Thanks
Old   March 24, 2010, 20:40
Micael Boulet
Micael is on a distinguished road
Hi Arash,
I have a little comment about your mesh. You can improve it by using unstructured tetrahedral cells. The boundary around the cylinder can be regular, though, thanks to boundary layers utility in Gambit.
Edit: sorry, I mean unstructured quadrilateral
Micael is offline   Reply With Quote
Old   March 25, 2010, 16:55
karine
Hi
i dont know how to do this...sorry
i can suggest that u use large time steps so u can get a quick solution
After getting this 'bad' solution, u can use smaller time steps
Old   March 25, 2010, 17:34
Behrang Asgharian
Hey!
Thanks for taking the time to answer this. I did that once. The thing is when i use big time steps it gets steady but the amplitudes are not correct and when I change delta t to a small one then, it gets unsteady again and takes some time to become steady. I think the amplitude problem with big delta t's is due to numerical diffusion. Do you think so?
Thanks
Behrang
Old   March 25, 2010, 19:44
karine
Hi
In fact , u will have a bigger numerical diffusion ( truncation error) and u will miss some of the flow motion. If u use a time step dt, u cant correctly simulate any motion with a time charachteristic less then dt/2 (shannon's theorem)
( U may be also violating the stability limits of ure scheme, what will give rise to wiggles)
Regards
Old   June 6, 2010, 23:29
Default Problem with flow rate enthalpy sign
  #30
Behrang Asgharian
I believe you can help me with this.
I put some Lines (from the menu 'surface-line') on my model in order to monitor the enthalpy flow rate. I use the flow rate integral which is
integral of rho*h*u.dA
the absolute values are OK but the sign is negative when it must be positive. I think this has got something to do with the inner product of u.dA.
Does anybody know how I should define the monitor line in order to get positive enthalpy flow rates?
By the way, if I use 'surface-rake' instead of 'surface-line', what will happen?
Thanks
Behrang
Old   June 16, 2010, 19:40
Default Saving a particular profile and load it in another case
  #31
Behrang Asgharian
Hi
I am running a case for which I need to give Fluent an initial condition. My question is: Can I save for example density throughout a case and load it in another case with different boundary conditions but with the same mesh? You know, I don't want all the data. I just need a part of it. Is this possible in Fluent???
Thanks
Behrang
Thread Tools
Trackbacks are On
benchmark: flow over a circular cylinder goodegg Main CFD Forum 9 June 20, 2011 13:02
Moving a Cylinder in cross flow after solving Dynamics equations of motion maruthamuthu_venkatraman OpenFOAM 1 November 19, 2009 13:55
Flow over a flat plate & Flow over a cylinder cfdxue Main CFD Forum 0 November 26, 2007 23:26
Anybody knows smth abt the flow around a cylinder? Wenxuan Main CFD Forum 3 March 20, 2007 17:19
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 14:32
