-   -   Reversed flow on pressure outlet (http://www.cfd-online.com/Forums/fluent/71376-reversed-flow-pressure-outlet.html)
MDinc December 28, 2009 22:40
Hi to Everyone and Merry Christmas,
Is ''reversed flow on pressure outlets...'' really a problem on Fluent that have to be fixed? Because, I have this warning message but there seems no problem on convergence of model.
There is way to fix the reversed flow problem that extending the domain to further away. However, I can not extend the model to further away because I am also trying to reduce the total mesh faces and elements so I cut the 3D-Truck model from the middle and then I have choosen pressure outlet for this half end of Truck. Should I change this B.C. (pressure outlet) to interior or outflow?
Regards,
Murat Dinc
teguhtf January 1, 2010 05:47
Hi Murat!!
That is nice question. I'm in the same problem too. well, i think the way to reduce back flow is lengthen tho outlet or to set the gauge pressure >0 pa. Interior can be applied only in the middle, it doesnt work in the end.
hope it helps
teguhtf:D
