How to animate the air flow patters inside a cylinder |
December 21, 2009, 15:01 |
Vijay
Rep Power: 17 |
Hello to everyone. I simulated the air flow patterns in a big cylinder. I don't know how to animate it. Can any one help me. Thanks in Advance.
December 22, 2009, 20:36 |
YH Tan
Rep Power: 17 |
blur question. Post picture of the view u want.
Herntan, Add Reputation if I am right |
December 28, 2009, 19:40 |
Abhijeet Karnik
Rep Power: 17 |
You can do it using Scene animation. Plot the pathlines at increasing steaps. (100, 200, 300 etc) and define each frame as key frame. Once you are done defining key frames, save it as mpeg. The fluent manual has scene animation which explains this (If my memory serves right).
December 29, 2009, 11:47 |
Arash
Rep Power: 16 |
If you want to see steady one, then you need to use Pathline:
Display > pathline> particle ID but if you want to see unsteady flow animation first go to : Solve > animate> define > select number of sequence > change Iteration to time step > again define > now select one of the Display Type Afterwards, go to Solve> iterate> select number of Type step finally, when iteration finish, go again to Solve> Animation> Play back > and watch and enjoy good luck |
Problems modeling subsonic engine air inlet with flow separation | TWaung | CFX | 2 | March 29, 2009 18:42 |
Air Flow around a stationary cylinder | basilwatson | OpenFOAM Running, Solving & CFD | 1 | May 26, 2008 06:37 |
Flow over a cylinder | Anna | Main CFD Forum | 9 | March 24, 2006 14:32 |
axial flow around a cylinder -heat transfer model? | Ralf Schmidt | Main CFD Forum | 1 | March 21, 2006 08:54 |
Flow around a cylinder at subcritical regime. | yousef | FLUENT | 0 | March 18, 2006 09:18 |
