CAD files
Old   January 12, 2010, 19:32
Default CAD files
Michaela Milakovová
MICKEY26 is on a distinguished road
Hi ! Can anybody tell me if is it possible to import files with grid or geometry from AutoCad to FLUENT 6.1 ? Thanks for answear !
MICKEY26 is offline   Reply With Quote
Old   January 13, 2010, 00:41
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you can try to export from Autocad an Iges file (or step file if available)
Then import it into Gambit and not Fluent
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 13, 2010, 03:18
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
You can export files as *.sat or *.stl but then you will need to transform the geometries to mass properties (command in autoCAD)... and it is difficult.... try using Solidworks or other software like Rhino.... from there it is easy...
Philipov is offline   Reply With Quote
[CAD formats] Hexahedral meshing of CAD files - Which free software? Wolle OpenFOAM Meshing & Mesh Conversion 14 November 22, 2014 21:40
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
