error mesage
Hi !
If I click on button Iterate, FLUENT donīt compute and write this : Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc pp, size 27541160, t 7, myid 1000000. Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () Can anybody tell me, pleas, what can I do with it ? Thank you very mutch !:rolleyes: |
Error message in Fluent sometime might not mean anything. just a minor program bug. just restart Fluent and do it again.
If keep repeating, i think ur hardware and OS might have problem. |
you are asking more RAM memory than you PC can afford.
Reduce your mesh, or switch to parallel process (eventually a PC with more RAM memory) Usually a 1 million cells mesh will ask 1 GB Ram memory |
Yes, it is lack of RAM.. you can try also to convert the mesh into polyedral.....
