pressure drop in the pipe
Old   February 5, 2011, 03:40
Default pressure drop in the pipe
mike
mike.mm is on a distinguished road
Hi Friends,
I am very new to fluent software and just now started learning fluent...
In that i have one doubt i have modeled incompressible flow through horizontal pipe.
1) i have given velocity inlet and pressure outlet as my boundary conditions.how to calculate pressure drop of fluid through pipe ?
2) In the above problem, if i know pressure and velocity of inlet fluid and i want to calculate pressure drop of the fluid. In this case how should i specify these specify my boundary conditions and how calculate pressure drop?
Please clear my doubt ..Thanks in advance...
with regards
mike.
mike.mm is offline   Reply With Quote
Old   February 5, 2011, 08:44
Amir's Avatar
Amir
Amir is on a distinguished road
Hi mike,
1) after you solved for flow field , you can plot pressure for example in centerline or also save that data . (in fully developed flow it should be linear)
2) in this case you can set exit as outflow , and allow flow to reach it's realistic pressure value . pressure drop calculation is as above.
Amir is offline   Reply With Quote
Old   February 6, 2011, 23:26
abdul moqeet hai
abdul moqeet is on a distinguished road
Hi Amir,
I am also new to Fluent
i am to model the air flow through a diagonal rectangular pipe, only the velocity of the air at outlet is known, as there is a suction fan at the outlet. plz guide what exact boundary conditions should i use???
with regards
Abdul Moqeet
abdul moqeet is offline   Reply With Quote
Old   February 7, 2011, 02:40
Amir's Avatar
Amir
Hi abdul,
some years ago I faced the same problem and I handled that with this tip:
you know velocity profile at the exit as a function of space , first you can use velocity inlet but with negative velocity magnitudes at the outlet !
after some iterations and convergence, you can find pressure change near outlet and change boundary condition to exhaust fan. by this you will have compatible boundary condition.
Old   February 7, 2011, 04:16
abdul moqeet hai
Dear Amir,
Many thanks for your response
please elaborate it a bit more as i am a textile engr by profession. so naturally i am not used to the terms. i have perceived the sense you wanted to communicate, to a good extent, but elaborate more if you can.
regards
Old   February 7, 2011, 07:58
Amir's Avatar
Amir
Dear abdul,
as usual we can set velocity at inlet but we can't at outlet. by setting pressure there, velocity profile will be found. but in this cases you can use a trick. we can assume outlet boundary as an inlet one but with negative velocity magnitudes.
after using this method and solving for flow field, you can change your boundary conditions to realistic ones, there you need pressure drop for example, you can use the result of first stage here.
Old   February 7, 2011, 10:31
-abdul- is on a distinguished road
Many thanks dear
i got your point.....
thanks again
Abdul Moqeet
-abdul- is offline   Reply With Quote
pressure drop
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
What's meaning of pressure drop for fluid? qihongming Main CFD Forum 1 April 30, 2009 12:05
Pressure drop in periodic turbluent pipe flow lou FLUENT 0 September 21, 2005 00:58
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
