-   -   Fluent SI engine tutorial problem (http://www.cfd-online.com/Forums/fluent/71925-fluent-si-engine-tutorial-problem.html)
Jonny6001 January 20, 2010 03:48
Hi, I am working on the tutorial by Fluent for injection in a SI engine, 2D.
I have everything set-up with the dynamic mesh and the rest of the case as described. The case solves for around 30 mins then it will get stuck with the message "advancing dpm injections".
I presume it has gotten stuck in an infinite loop and I can't interrupt or close the program. It has usually done 10000 itterations by this time with good residual values.
I can see the displays of what's happening at each step and the injection seems to be working as it should.
I find this strange since it's a Fluent tutorial which they and other people must have checked a lot.
I have set ar URF involved with the injection to 1.
Does anyone have and ideas or possible advice?
Thanks a lot.
Jonny6001 January 22, 2010 17:47
I managed to get a solution by reducing the splash in the wall function from 4 to 3.
Aziz84 May 6, 2010 03:19
Hi Joanny,
Can you help me how you solved it? I try to run the tutorial as well, but i got different error in which the iteration stucked and mentioned there is negative cell volume. I had followed the tutorial step-by-step, but getting confused why I got this error. Your help is very much appreciated.
thanks.
ark March 25, 2011 04:32
I am also facing a similar problem.
I am following a tutorial on cold flow simulation in engines and it runs fine. But when i make any modification to the injection velocities (define>injections) , the iteration runs for around 10000 and gets stuck after around 30 minutes.
What should i do? If i try it in a powerful system will it help?
tsram90 January 22, 2012 20:26
Thanks a lot.
In which tutorial file do you have injection etc mentioned? Can you send it as a pdf to sankarram90[at]gmail.com
