November 6, 2019, 16:35 |
Animated Solution Steady State Solution
Anonymous
I would like to perform a simulation of a pump head using fluent. My aim is to be able to view an animation of the impeller and how turbulence and pressure changes as the impeller blades sweep past outlet. I've already done a steady state simulation, however I am not sure that the contours I see are an average of values during one full revolution of the impeller, or if the contours are for that specific position. Many Thanks. |
November 8, 2019, 09:45 |
Alex
Rep Power: 46 |
Depends on how you performed the simulation. Here is a nice summary of the different approaches for rotating parts: https://www.cfd-online.com/Wiki/Best...stage_analysis
November 9, 2019, 11:51 |
Anonymous
Thanks for the response.
I have 3 cell zones: inlet (stationary), volute (stationary) and impeller (undergoing rotational motion). I then have the boundary walls of the impeller rotating as well. I therefore think that, based on the link you'd kindly provided, this is a frozen rotor simulation. As the articles outlined, the results that I get are dependant on the rotor positions. I performed a single stage centrifugal scenario, however, I am looking to perform a simulation of multistage pumps. Would it still be a good idea to perform the simulation using fluent under steady state conditions or are there better alternatives out there that are better suited to calculating and presenting the solution. |
Display Modes | |
The difference between steady state and transient | JuPa | CFX | 36 | December 9, 2019 23:50 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
plz help,urgent, vof model steady state | Garima Chaudhary | FLUENT | 4 | March 15, 2018 13:22 |
steady state, laminar vof_model | Garima Chaudhary | FLUENT | 0 | May 24, 2007 04:11 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 15:37 |
