January 27, 2010, 11:25 |
Time-Varying Inlet Velocity
CFDFSI
Rep Power: 16 |
I'm trying to impose time-varying velocity at the inlet. Can someone guide me on how to impose the bc ?
Thanks. |
January 27, 2010, 16:00 |
Rep Power: 19 |
Use a UDF - you will find an example of a an unsteady velocity boundary condition in the Fluent UDF manual.
Do |
January 27, 2010, 16:18 |
CFDFSI
Rep Power: 16 |
thanks for the reply.
for example: if i want v(t) = 0.1*t for 0< t < 1 at the inlet, is the following UDF correct ? Code:
#include "udf.h" DEFINE_PROFILE(transient_velocity, thread, position) { float t, velocity; face_t f; t = RP_Get_Real("flow-time"); velocity = 0.1*t; begin_f_loop(f, thread) { F_PROFILE(f, thread, position) = velocity; } end_f_loop(f, thread) } |
January 27, 2010, 19:25 |
Rep Power: 19 |
Looks OK (I didn't tested your code in Fluent), however if you want to apply this only for 0< t < 1 ... you've missed a test condition.
Do |
September 24, 2010, 16:26 |
Rep Power: 16 |
dear cfdfsi,
I was using your UDF to impose a time varying velocity inlet on a 3D cylinder. However, I'm not getting a plug profile with it. Did anything similar happened to you? Thanks! |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
How to set a time varying velocity field as a BC? | Mikro | OpenFOAM Pre-Processing | 5 | March 19, 2009 04:38 |
UDF paraboloid velocity inlet | Ronak Shah | FLUENT | 0 | June 4, 2003 09:44 |
velocity more than INLET velocity | neu | FLUENT | 3 | May 13, 2003 04:56 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
