Time-dependent viscosity implementation in fluent
Old   January 27, 2010, 22:18
Default Time-dependent viscosity implementation in fluent
Real Name :)
ComputerGuy is on a distinguished road
Does anyone have an example (UDF/literature link?), or know if this is possible to do in fluent? Can one model thixotropy or rheopexy (rheopecty) in this program? I realize it will be a UDF implementation, but I'm unable to see how I would track parcels of fluid to monitor their shear rate vs. time, as thixotropic fluids have age-dependent viscosity.
Could this be implemented by injecting neutrally buoyant, very tiny particles and monitoring their shear vs time, and adjusting the viscosity of the fluid volume which contains them?
Thanks for you help.
ComputerGuy is offline   Reply With Quote
Old   April 19, 2010, 10:31
Agustin
Agustin is on a distinguished road
You can use the croos model , if you know the coeficients of the equation, you can create a new component in Define-Materials and viscosity, you select the croos model and you only have to introduce the parameters of the model.
In the tutorial of fluent 2007, the tutorial number 8 talk about the non-Newtonian transitional flow in an eccentric annulus, you can find this in google.
I don't know if you ask about it, but it is the only thing that I know.
Sorry for open an old topic.
Agustin is offline   Reply With Quote
Old   September 20, 2011, 03:11
MOISE DION
moisedion is on a distinguished road
I'm curious to know how you did solve this time dependent rheological Simulation... Was it by UDF or by creating a Solver in OpenFoam? Also, Cross Model is not for Time dependency but Shear Rate Dependency (thinning)...
Last edited by moisedion; September 23, 2011 at 05:00. Reason: Provide further details
moisedion is offline   Reply With Quote
thixotropic, time-dependent, udf, viscosity
Regarding Implementation of Hershel Bulkley Model in Viscosity correlation Pathak FLOW-3D 0 August 24, 2009 06:34
Time dependent gate opening krish FLUENT 0 June 17, 2007 01:17
residence time contour in Fluent kk FLUENT 0 May 1, 2007 22:56
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 12:32
