What happens by doing Bandwidth Reduction?
Hey friends,
In fluent, what happens when u do bandwidth reduction by grid>reorder>domain Why and when do u do it? Thanks |
After you read your mesh in Fluent you can do the bandwidth reduction. Basically Fluent will renumber the nodes of your mesh in order to have a "more diagonal" array. This will allow you to use less memory and also the solution will converge faster.
Do |
Hey DoHander,
So basically, it means that one should make it a practice to always do bandwidth reduction after reading any mesh into Fluent... |
If you use any of the implicit solvers of Fluent yes, you should always do the bandwidth reduction. For the explicit solver this is useless.
Do |
Thanks DoHander :)
I also have a question on this, till what value you need to reorder to achieve the most optimal bandwidth? Seem to me that the lower the bandwidth value the better?
details can be found here...
http://en.wikipedia.org/wiki/Banded_matrix This also clearly shows why you cannot have advantage of reordering for explicit solver... |
Thanks :) /Rasmus |
Implicit solvers solve liner systems: e.g. Ax=b for the unknown x. When A has a lower bandwidth, certain algorithms (i.e. Gaussian elimination) are faster. Explicit solvers don't solve linear systems, they simply compute Ax=y for a new y. Regardless of the bandwidth of A, it's simple algebra. |
