-   -   solution not converging for fine mesh.. (http://www.cfd-online.com/Forums/fluent/72287-solution-not-converging-fine-mesh.html)
saurabh.deshpande88 February 1, 2010 10:18
Hello everyone,I am doing analysis of flow around a NACA 0008 airfoil. Using gambit and fluent for the purpose.
When i use a coarser mesh (i.e. nodes=1,500) my solution is converging and i am getting the results.
But for a fine mesh (nodes=12,000) even after 1,60,000 iterations my solution is not converging and there is not a slightest sign that it will come down! In fact the "residual vs iterations" curve follows a zig-zag pattern. Why is it so?? please help. thanks..
IMP DATA:
residual: 1e-06
inviscid flow, angle of attack=20 degree
Discretization schemes: pressure= presto
momentum= second order upwind
Pressure velocity coupling: simple
underrelaxation factors have been reduced to the extent of 0.01 for pressure and momentum.
DoHander February 1, 2010 16:50
Using a small mesh starts to smell like a DNS (Direct Navier Stokes) but if it is 2D and steady is not DNS :). The moral is - if you use an extremely fine mesh this must be fine enough for representing the physics of your case. A fine mesh will usually catch small zones of separations and reattachments "invisible" for a coarse mesh - this is probably why you can't obtain a convergent solution (steady ?).
Do you use a turbulence model in your simulation ?
Do
saurabh.deshpande88 February 2, 2010 11:23
Hey thanks for the reply.:)
I got what you mean to say. due to "seperation and reattachment" of flow at micro level velocity changes continiously and solution is not getting converged.
This also explains why solution was converging for lower angles of attack (< 20 degree) for the same fine mesh. seperation starts as angle of attack increases and solution convergence stops.
i am not using a turbulent model. i am a begineer in the field of CFD. i am using inviscid model. should i change to turbulent models?
(But :confused:, actually if i am considering inviscid model then viscosity is zero and hence there should be no skin friction, no boundry layer formation and hence no seperation.. then why is it not converging? )
