-   -   Moving mesh problem (http://www.cfd-online.com/Forums/fluent/72353-moving-mesh-problem.html)
Geon-Hong February 3, 2010 03:43
Moving mesh problem
I tried to analyze a shrouded propeller with moving mesh.
I tested FLUENT 6.3 under both x64 CentOS Linux and WinXP professional edition(32bit).
After I set up the problem to solve it with moving mesh, I checked the grid but no problem was occurred.
However, when I started to iterate with unsteady solver, then I encountered following error messages...
WARNING: non-positive volumes exist.
divergence detected in AMG solver: pressure correction
Primitive Error at Node 5: floating point exception
Why this happened? :confused: Please somebody help me...TT
I also tried to solve the problem with same setting but stationary mesh, there was no problem like this at all.
When I set an moving mesh for an open propeller, there was no problem too.
Why this happened and what should I do?
mas February 3, 2010 23:09
for the non-positive volumes problem, you should check your remeshing settings, eg. min/max length scale and size remesh interval.
ekakavand February 7, 2010 01:44
AMG solver
Hi Geon
did you solve your problem? I countered with this error too, I change factors of solve but i do not get results.
thanks in advance.
elahe
Geon-Hong April 5, 2010 03:24
Dear ekakavand
Just made grid again and now I have no problem with my computation.
Sincerely,
Geon-Hong
