Is pressure-based solver adequate for a transient simulation ? |
May 23, 2022, 22:28 |
y t b
Rep Power: 3 |
Hi guys, I need some advice on an adequate solver setting to simulate transient flow.
I’m trying to simulate a high-pressure pneumatic valve flow for 2 seconds, which is quite short. The overall flow speed would not become over Mach 3. Since some geometries are moving, a dynamic mesh would also be necessary. Would there be any standard for setting a solver and schemes? I’m trying to use a pressure-based solver and standard k-e turb model with a small time-step (1e-6 ~ 1e-7). Max iter would be a default, 20. But, I’m concerned about using a pressure-based solver, which is implicit, when simulating such shot time transient simulation. Any advice? Thanks for all. |
May 23, 2022, 23:15 |
Lucky
Rep Power: 65 |
The smaller the time-step, the more it makes sense to use a pressure-based solver over a density-based one. I've also used a pressure-based solver for Mach numbers greater than 5 and found no issues. I don't have any advice except to tell you that the pressure based solver works for transient problems.
Pressure based and Density based Solver | Xobile | Main CFD Forum | 39 | August 19, 2020 06:04 |
Wrong fluctuation of pressure in transient simulation | caitao | OpenFOAM Running, Solving & CFD | 2 | March 5, 2015 21:33 |
the role of speed of sound in pressure based solver | 759599290 | Main CFD Forum | 0 | March 3, 2014 02:39 |
transient simulation of a rotating rectangle | icesniffer | CFX | 1 | August 8, 2009 07:25 |
pressure based solver | fadhil | FLUENT | 2 | May 28, 2008 06:29 |
