February 3, 2009, 20:38 |
wall shadow
Dear
May you explain what is the difference between wall and wall shadow, because some times when I define a face as wall in Gambit and after that go to fluent I see that additional wall is defined in boundary layer of Fluent as wall shadow. Do I have to give the wall shadow the same properties of the wall like temperature and thickness. I'm looking forward for your reply Yours Thanks |
February 5, 2010, 06:07 |
Byron Smith R J
Rep Power: 17 |
amar
If you use a wall with material or fluid on both sides of it, Fluent will generate a shadow wall for computations on the other side. |
What does wall-shadow mean? | TOM | FLUENT | 2 | December 19, 2010 12:34 |
match uds boundary condition in wall & wall-shadow | pour | FLUENT | 0 | May 20, 2008 08:56 |
Shadow Wall | Soheyl | FLUENT | 1 | March 12, 2008 13:45 |
how to get rid of shadow wall | ssn | FLUENT | 2 | January 3, 2008 12:00 |
wall & wall shadow net heat flux | Barbaros | FLUENT | 1 | August 5, 2006 02:00 |
