Home > Forums > FLUENT
Operating Pressure!
Old   February 8, 2010, 14:35
Default Operating Pressure!
spk
spk is on a distinguished road
Hi guys,
I simulate cavitation in a centrifugal pump. At the exit of the pump i have defined pressure-outlet. At the inlet velocity-inlet. I have set the operating pressure 101325 Pa. I cant understand the significance of the reference pressure location!! Where will i define it??
The point that i defined it, has gauge static pressure 0?
Thanks a lot!!
spk is offline   Reply With Quote
Old   February 10, 2010, 05:35
Jouke de Baar
jack1980 is on a distinguished road
Hi, I'm not completely sure but I think the reference pressure will be ignored in your case. I think the reference pressure is only used when you have no pressure boundary conditions (say, velocity_inlet and outflow), in order to keep the overall pressure from floating.
If you do need it, put it in a nicely behaving place, for example avoid being close to the phase-1/phase-2 interface.
jack1980 is offline   Reply With Quote
Old   September 16, 2010, 17:36
Unhappy Where is Reference Pressure Location?
kamal galedarzade
kamal_g65 is on a distinguished road
Hi Jack1980
I want simulate a two stage centrifugal pump, by Fluent. Pump contains: inlet that is a bent pipe, two impellers, diffusers and outlet is a dual volute.There are not pressure-related boundary conditions(e.g., pressure inlet or pressure outlet) in my problem B.C (because I used Velocity-inlet for inlet B.C and Outflow at outlet). Do I enter (X, Y, Z) coordinates for Reference Pressure Location? (for example, the inlet surface center are (-526.5, -271.6, 127.4 ), Do I enter same point for Reference Pressure Location?)
I am confused in the model. Please help me.
Thanks.
kamal_g65 is offline   Reply With Quote
Old   September 19, 2010, 06:50
spk
Hi kamal_g65,
You have to enter x,y,z at the point where there is atmospheric pressure!
Originally Posted by kamal_g65 View Post
Hi Jack1980
Thanks.
Old   September 19, 2010, 08:39
Steven Qhin
chaozhong.qin is on a distinguished road
That is right, if you have the pressure boundary condition in your simulation, since you are using the gauge pressure, which means the reference pressure is included already.
chaozhong.qin is offline   Reply With Quote
Old   September 20, 2010, 03:07
kamal galedarzade
This is means if relative pressure at inlet equal 700kPa, and i want velocity-inlet define at inlet, i have operate below:
operating pressre= 700+101=801 kPa
Reference Pressure Location = it is same point at inlet surface center ( point: -526.5, -271.6, 127.4 )
Old   July 28, 2015, 03:28
Aja
aja1345 is on a distinguished road
what is your exact meaning of 'floating'?
I am grateful that some one guide me.
Thanks
aja1345 is offline   Reply With Quote
Thread Tools
Trackbacks are On
OPERATING PRESSURE manish FLUENT 6 February 25, 2011 05:40
operating pressure problem alp FLUENT 1 June 12, 2008 17:24
Operating Pressure (Natural Convection problem) Andrew Tress Main CFD Forum 1 July 3, 2006 16:00
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
floating operating pressure Shankar FLUENT 1 January 30, 2004 05:08
